New from Canada
  • michael47
    • Oct 2016
    • 118
    New from Canada
    Hi
    I have just purchased a Marlin LHD roadster first on the road in 1994,it is MGB powered and seems to have a triumph gearbox with O/D in 3rd and 4th..It has no top of side curtains witch I would like to change as spring and fall can be rather brisk here.I also drive a 1953 Moggie with a 1275 and disc brakes.I have admired Marlins for years and ca not believe my luck in finding one.
    Re: New from Canada
    If it has a Triumph gearbox it is highly likely it has a Marina B series engine, very similar to an MGB but subtly different.
    • Blue Marlin
      • Mar 2015
      • 314
      Re: New from Canada
      Hi, welcome to the club.
      I have no roof or side screens either, a little fresh all year in Scotland
      Stumbling around in the dark
      Marina based SWB roadster
      • michael47
        • Oct 2016
        • 118
        Re: New from Canada
        subtly different? How different? I remember Marinas having a single carb ,Mine has a single downdraft weber which I think was a necessity do to LHD steering column .How does one tell the difference between a MGB and Marina block? I am guessing it is a Marina as there is lots of Marina parts on the car.
        Thanks
        Michael
          Re: New from Canada
          Marina, mechanical fuel pump, MGB electric. Starter motor, Oil filter, Backplate, flywheel, clutch etc. Not everything is obvious.
          Not a real problem just beware if ordering parts.
          • michael47
            • Oct 2016
            • 118
            Re: New from Canada
            Thank You Very helpful
            Michael
            • michael47
              • Oct 2016
              • 118
              Re: New from Canada
              Wow picked up car this AM and spent the day driving it . It looks beautiful inside and out, the BMC B series engine pulls well only problem is the gearbox even double clutching it catches going into 3rd and most of the time it won't downshift from 4th into 3rd I guess I should go to the roadster forum and post the problem , Even with the gearbox problem I am a very happy owner
              • dbazdavies
                • 409
                Re: New from Canada
                some pics would be nice especially the LHD conversion !!
                • michael47
                  • Oct 2016
                  • 118
                  Re: New from Canada
                  Will try to post pic
                  • michael47
                    • Oct 2016
                    • 118
                    Re: New from Canada
                    • Blue Marlin
                      • Mar 2015
                      • 314
                      Re: New from Canada
                      Looks good, like the colour scheme
                      • michael47
                        • Oct 2016
                        • 118
                        Re: New from Canada
                        Thank you credit goes to previous owner/builder Peter B
