Wishbone bushes
  • Dbdelboy
    • 43
    Wishbone bushes
    Can someone tell me the right bushes for the wishbones and where to buy
    • 1648
    Re: Wishbone bushes
    I assume from the location of your post that you Have a Cabrio set up.
    The Cabrio top wishbone bushes are the same as the lower inner track control arm bush.
    My Supaflex part numbers are:
    Track Control Bushes
    Supaflex
    SPF0770
    2x Top Hat Type 10m.m. Bolt
    Upper Wishbone Bushes
    Supaflex
    SPF0770 KSS
    The top ones were purchased much later than the lower inner so not sure what the KSS means in the part number.
    The problem with fitting the top ones is accessing the nuts on the U-brackets as they are very close to the inner wing! That's why I still haven't fitted mine! Take care to note the shim thickness and positions when removing the U-brackets and replace in the same position.
    Peter.
      Re: Wishbone bushes
      The bushes Marlin supplied me were Ford orignals, Motorcraft. I've kept the packet just in case. Legends on separate lines are
      1619120
      EBJ12
      81AB 3063 BB
      INSULATOR
      C55763 H1(WP)
