Marina 1.8 gearbox needed
  • Doublerat
    • Jun 2013
    • 35
    Hi
    I have a Marlin Roadster with the 1.8 marina engine and gearbox. The engine is strong but the gearbox is very tired. Does anyone know where i can find a replacement? Or maybe where I can get mine reconditioned
    Thanks for looking and any help will be appreciated
    Phil
    Re: Marina 1.8 gearbox needed
    Hi Phil, Try Stuart on 07517626540.He is near Poole Dorset. He was mentioned on the forum recently. Someone may point out where. He breaks Marinas etc. I have no connection except as a satisfied customer.
    • Doublerat
      • Jun 2013
      • 35
      Hi Dave
      Thanks for the info' I will give Stuart a ring tomorrow
        Be aware that the input shaft for a 1.8 is different from a 1.3, a different number of splines to engage in the clutch plate.
        • Doublerat
          • Jun 2013
          • 35
          Thanks for the heads up Steve, I didn't know the input shafts were different and would probably have made an expensive mistake! Much appreciated
          • velovol
            • Nov 2012
            • 143
            Hi, I've got a 1.8 Marina gearbox under a tarpaulian which I removed a couple of years ago when I fitted an MGB overdrive box. I haven't looked at it recently but I don't recall any problems driving when it was on the road. I'm in West Sussex.
            • Doublerat
              • Jun 2013
              • 35
              That sounds perfect, have sent you a pm
