Heater Dash Vents for a Hunter / Cabrio
    • 1641
    I am looking for a way to get some warm air over my right glove as I always get a cold right hand on frosty days (top down of course)!
    I seem to remember seeing a heater vent in each end of the dashboard top cover in an early Cabrio, possibly the early demonstrator? Does anyone have any details of this? Who made the “grille” or was it a fabricated item or maybe, as it’s not seen except when the door is open, it was just an open slot? Did it connect to a Sierra heater box and if so where?
    As I never listen to the radio I have even been considering using the dash tweeter holes but can’t find an eyeball vent that will fit the 42mm diameter hole. The nearest are aircraft cabin air vents at silly aircraft prices! Peter.
  • philcoyle
    • 379
    Re: Heater Dash Vents for a Hunter / Cabrio
    Hi Pete,
    how about the other option 12volt heated motor cycle gloves, put on gloves, plug in , and go. No messing no wiring no hassle.
    Phil
      • 1641
      Originally posted by phil.coyle View Post
      Hi Pete,
      Phil
      I had considered that, but they all seem very bulky for car driving. I even thought about trying a piece of thin vinyl tube from the heater vent and fitted inside the right glove but I think a dash vent is more elegant! Peter.
        • 929
        Some of the guys on the SKCC forum us the heated gloves and vests They seem to work quite well...
        How about these... http://www.ebay.co.uk/itm/Keis-Heate...-/190909728152
        • keith_h
          • 549
          I made a heater from the Sierra 3 speed blower and heat exchanger. I designed it so that I could use the Sierra dash outlet controls and side vents with a 120 deg swivel. It works very well and also can dump a lot of heat if caught up in a summer traffic jam
            • 1641
            Thanks for the info Keith. My set up is similar in the footwells except for your natty swivel outlets. However I don't have the luxury of the double fascia vents that you have in the centre console. I think Mike G has the same in his Cabrio. I am planning to redesign the centre console in mine to get rid of the radio / tape player that I never use, so maybe that will give me the chance to do the same. Peter.
