Fitted 2 new suspension arms. I had to employ the side of the garage to refit the anti-roll bar chassis mounts.
Then I found the toe-in was about 4 degrees, it should be about 11 minutes so I adjusted the toe-in.
However at 1C I had to give in as I couldn't feel my fingers.
Still it will be a quick fix tomorrow as it was close to correct when I had to finish.
