Message originally posted by: Ian Hickson
Hello there, yes its me again, I've sorted out the fuel pump problem. Thanks for all your Help.
The car now starts o.k. but it will only tick over at about 1200 rpm and I can't control the engine speed. if I touch the throttle it speeds up to 1500 rpm and stays there, not only that the engine get very hot very quickly. Has any body got any idea what could be wrong.
The only wire on the engine loom that I can't connect is the speed sensor, because there is no sensor on the gear box, could this be the problem??
Thanks Ian..
Thanks Ian..
