clutch pipe for marina based roadster
  • victorday_31
    • 17
    Have replaced the seals in master & slave cylinders but have a problem with leaking fluid. Thinking of re-tapping threads on the pipe, does anyone know if they are 3/8 unf?
    Thank you
    Vic Day
    Re: clutch pipe for marina based roadster
    All the threads on a standard Marina hydraulics are UNF.
    Not sure why you should want to retap any hydraulic ports, a properly formed copper pipe, when tightened by its retaining screw, will deform the copper into its seating.
    Perhaps you can be more specific where the leak is coming from.
    • fouter
      • Dec 2015
      • 37
      Hi Vic,
      Have you had a close look at the union where it clamps on the swagged pipe, if it's a brass fitting and has been over tightened these can crack and the thread will bottom out before it clamps the copper pipe.
      Best Regards
      Graham
      • victorday_31
        • 17
        Thank you Steve & Graham. Should I require a new pipe, where would be the best place to go? I bought one on line but pipe diameter is not correct, smaller like a brake pipe.
        Thanks,
        Vic
          eBay has a clutch hose here or there same size across the Marina/Ital range whether 1.3, 1.8, 1.7, 2.0. So not sure where it what you bought previously.
          Still confused, even more, are we talking e Red plastic pipe or something else?
          The red pipe has pre formed (metal) ends, not deformable to the same extent as copper.
