Roadster Rebuild Diary from Cornwall
    Re: Roadster Rebuild Diary from Cornwall
    That is all looking good, I'm feeling slightly embarrassed that I'm still working up the enthusiasm to re-visit my leaky choke mechanism... small job, but lacking enthusiasm to continue the saga. I should have returned the carbs as 'not fit for purpose' instead of deciding to correct the bad workmanship myself!
    • meverett
      • 662
      Been busy today cleaning up the bulkhead.
      Before.
      After.
      And fitted to the chassis.
        • 929
        If you haven't already thought of it you should consider adding the bulkhead strengthening to stop it cracking.
        • meverett
          • 662
          Thanks for that. I have got it and dug it out to be stripped and repainted.
          It is the triangle that bolts onto the servo mounting plate and bolts to the side louvred bonnet. Is this the best design or is there one that takes it down to the chassis?
            • 929
            #20
            It's the factory design that I think most people use. I used an old kart track rod and made a couple of brackets to fix it between the peddle box and the chassis. There are some pictures in my blog. I may have another track rod lying around, I'll have a look in the week.
              #21
              I put a piece of alloy angle from side to side across the top of the tunnel and pop rivited it top and bottom as a permanent fixture. I'll try and find a pic.
                #22
                Here we go, you can see it running along the fold.
                • meverett
                  • 662
                  #23
                  Thanks for the advice, I will have to find some angle aluminium and do the same.
                  Did it interfere with the accelerator pedal fixing bracket?
                    • 929
                    #24
                    I have something similar as well as the brace. I thiBK it should be fine. Mine is at the limit of what the studs will fit through.
                      #25
                      From memory, and it is a long time ago, no, there wasn't any problems and its been like that since 1990.
                      • meverett
                        • 662
                        #26
                        Been stripping the bell housing off the gearbox today to clean up ready to paint. The first motion shaft oil seal was perished and gasket fell to bits so ordered a new set. Put the build wheels on and noticed I have got a camber issue as in the picture. I haven't taken any measurements yet other than one side is sitting 5 mm higher on the damper (centre to centre of mounting bolts) even though I set the outer ends of the suspension arms 150mm lower than the inner mounting so some minor adjustments to be made.
                          • 929
                          #27
                          I wouldn't worry until you put the engine and box in as it will settle down then.
                            • 2790
                            #28
                            Suggest as Andy says you wait a while. May even be better to wait until its all together then get in and and bounce it around a bit
                            • meverett
                              • 662
                              #29
                              Ok thanks will wait. I have a set of adjustable tie rods that I am going to clean up and replace the standard ones as well.
                              As for a panhard rod in my other thread, do they help, would the RTL linkage be better? That looks a neat solution to the sideways movement of the back end. Has anyone fabricated one at home?
                                In case you haven't noticed the bottom bolt in the bell housing has a copper washer and needs to go back in the bottom bolt hole.
