Ital rear hub nut size?
  • meverett
    • 662
    Hi guys, just stripping the 1.3 ital rear axle down for a complete refurbish. The casing is completely stripped ready for wire brushing and paint, got the hubs off the half shafts (sod of a job) and the nuts look like they need replacing. Anyone know the thread size and where I could get a couple?
    Ordered some QH wheel bearings, oil seals and gaskets, just need a pair of new nylock nuts.
    Cheers, Martin.
    Re: Ital rear hub nut size?
    Pretty sure it is the same as a Triumph rear hub size 5/8th UNF. Earl parts or Rimmers should stock. Original part number 510618
    Even though the axle runs with EP90 oil the wheel bearings sit between two seals and need to be packed with grease.
    • meverett
      • 662
      Great thanks for that Ben. I will order some.
