Engine fan
  • Gareth
    • 502
    Engine fan
    Hi. Question to the audience...
    Look at the picture attached and tell me if the engine fan
    is the right way round. Think I'm going mad! It rotates
    clockwise viewed from the front but seems to be pushing
    more air forwards. Wasn't me that fitted it. Only just noticed.
    Is there a more efficient plastic one that would fit onto the water pump?
    Cheers Gareth.
    • 929
    Re: Engine fan
    I would go electric, IMHO the fan is for to far away from the radiator to be effective. The modern fans are more efficient, mine only comes on in stop-go traffic
    • Gareth
      • 502
      Re: Engine fan
      Already got electric fan on the front Andy. But the engine fan just looks wrong and I can't believe I've only just noticed it! Just wondering if there's a plastic one that would be a staight swap?
      Gareth.
        • 1641
        Re: Engine fan
        Originally posted by Gareth View Post
        Already got electrif contained in a shroudc fan on the front Andy. But the engine fan just looks wrong and I can't believe I've only just noticed it! Just wondering if there's a plastic one that would be a staight swap?
        Gareth.
        Agree with above it is too far away. Behind rad fans will work better if conntained in a shroud so it sucks air through the whole core. More importantly the fan is on wrong way around. The concave curve should be facing the engine so the blades will scoop the air rearwards. At the moment they will create a lot of turbulence but not much airflow. Peter.
          Re: Engine fan
          Andy is probably right about both the distance and getting an electric fan(opinion varies on that as it will obstruct some air flow when under way ).
          But it does look to me like the fan is the wrong way round(back to front) and is not throwing the air back. Later cars had a plastic fan which looks like its more efficient.
          Pete beat me to it so more than one brain thinks alike
            • 929
            Re: Engine fan
            Gareth.
            If you already have an electric fan remove the mechanical one as it is just using power at the moment.
            Pete - I keep thinking of replacing mine because it doesn't have shroud at the moment (it's e old Kenlow type) - any recommendations?
              • 2790
              Re: Engine fan
              Hi Gareth. I don't have a pic of this area post rebuild but this is a "before" pic. The electric fan sits nicely between the rad and the steering rack and there's no mechanical fan
              The car has done several thousand miles like this so I am hoping it will be OK, the fan shroud should pull the air through
              Could you put yours in a similar position and reverse the electrics ?
              HTH Rgds DC
                Re: Engine fan
                I can't convince myself that the fan is pushing rather than sucking through the rad.
                  Re: Engine fan
                  These pics any help? It was the biggest I could fit in. Mounted with two ally brackets at the top and tucked in between the rad and rack. It's controlled with the thermostat you can see bolted to the side with the stat. sensor going in under the top hose into the rad.
                  I've also put an override switch on the dash for when I get stuck in traffic but have rarely had to use it. The temp just comes up to the engine thermostat temp and that's it. Set the fan stat, trial and error, to cut in at the point where the temp gauge starts to rise but to honest it seldome cuts in.
                  Rad by the way is an 1800 one.
                  Hugh.
                    • 1641
                    Re: Engine fan
                    In theory yes, but it's like a stalled aircraft wing and will produce lots of turbulence as currently fitted. The curve needs to go the other way for good airflow across the blade(s). Hence my suggestion to turn it around. Peter.
                    • Gareth
                      • 502
                      Re: Engine fan
                      It definitely fitted the wrong way round but as it is in the picture it's also running backwards! As Pete says, lots of turbulence but not alot happening!
                      Can't believe it's probably been like that since its been built!!!
                      Currently off the car and being painted. So I'll report back and let you know how much difference it makes the right way round.
                      Gareth.
                        Re: Engine fan
                        Beware the plastic fans, they have a tendency to bend towards the steering rack and its mounting bolts especially at 5000 rpm.
                          Re: Engine fan
                          Can't you try a smoke test to see which way air is flowing? Should be simple enough with one of those joss stick thingy's!
                            Re: Engine fan
                            Just to be clear the engine does turn clockwise from the front, it's the right fan, just mounted the wrong way round.
                            Shrouded fans are good. In my experience it's airflow through the rad that is important, whilst the car is in reasonable motion there is plenty of airflow if you have a re-cored radiator, the electric fan is only essential when in slow moving traffic or stationary.
                            • Gareth
                              • 502
                              Re: Engine fan
                              5000 rpm? Don't think my engine would stay together at 5000 rpm!! Lol.
