Delaminating windscreen
  • rjstyles
    • Apr 2017
    • 1
    Does anyone know where I can get a new windscreen fitted for my Roadster?
    The existing screen has started delaminating, it doesn't seem to have got any worse since I bought the car 3 years ago and has just passed the MOT but I'm preparing for the worst.
    Roger
    Re: Delaminating windscreen
    Never heard of that, there is always a first! Searching the Roadster forum for details for windscreen will throw up a few options often from recutting an early Landrover flat screen. It's time to start doing your homework with your local windscreen companies.
      • 929
      The ones that specialise in coaches seem to be quite helpful
      • Blue Marlin
        • Mar 2015
        • 314
        My windscreen is also delaminating around the edges but is not too bad at the moment. What is more of a worry is the small crack at the O/S edge where PO drilled the frame to fit a mirror and went a little too deep.
        When that spreads into the wiper swept area I will also join the new windscreen saga
        Stumbling around in the dark
        Marina based SWB roadster
          • 1233
          There has been quite a number of roadster windscreens over the years which suffered from this problem. I assume the cutting and then the standard of bedding and sealing must contribute. No problem to have ome cut, but you can have some fun fitting the new screen.
            • 2790
            Hi Danny et al..................don't forget it's also good fun trying to get the old one out in one piece
              • 929
              If the old one is no good do you need to get it out in one piece?
                • 1233
                It can be handy as a template for the new one
                  • 929
                  I did wondered that. I would get some card and make a template of the visible area first just in case it breaks.
                    There is a brief write up in the Pit Stop 2008 Feb/Mar issue page 13. By Patrick Hobbs. Have fun! been there and got the T shirt. But I was replacing my original screen after chassis repairs back at the factory.
