Took the Sportster for it's MOT last wednesday (glad to say it passed) and whilst there I asked for the axle weights. As I operate the relevent swiches and controls during the test and the tank was full of fuel at the time, the front was 400kgs and the rear tipped the scales at 510kg. I don't know what a tankful of fuel weighs, but I weigh 77kg approx so my guess, without driver and fuel there is a very nearly 50/50 dry weght.
Sportster weight.
Tags: None
Re: Sportster weight.
Goodness me Ben, you should know we use the metric system in this country. You should have said “Four point five five litres of petrol weighs between 6 and 6½ lbs”. (Smiley face!)Originally posted by b_caswell View PostA gallon of petrol weighs between 6 and 6½ lbs. Unleaded that is !!
There are quite a few VOSA operateted weigh bridges around, usually combined with commercial vehicle testing centres.
I had had my car weighed at a site next to the A23. Free if I didn't want paperwork and a small charge if I did.
If you have a council waste site nearby, they are equipped with weighbridges, it might be worth asking, you never know!MOC member since 05/97
I'm fairly sure all Mot stations have to be able to weigh the axles to assess brake efficency.
Yours didn't! But for a commercial vehicle tester it's a requirement.Originally posted by copperleaves11 View PostI'm fairly sure all Mot stations have to be able to weigh the axles to assess brake efficency.
I think everything is now recorded by DVLA, almost certainly for modern cars.MOC member since 05/97
Quote: Goodness me Ben, you should know we use the metric system in this country. You should have said “Four point five five litres of petrol weighs between 6 and 6½ lbs”. (Smiley face!)
See even you Paul couldnt work out what 6lbs is in kilos(and I cant be bovered)
The reason we use metric litres for fuel is so you don't realize how much a gallon costs!!
Count down markers on motorways are still in yards
Road signs in miles
and most important beer in pints!!Last edited by b_caswell; 28-05-17, 10:59 AM.Ben Caswell probably not the last word on anything here!!
Spirit measures went metric in 1985!Originally posted by b_caswell View PostSee even you Paul couldnt work out what 6lbs is in kilos(and I cant be bovered)
Road signs in miles
The Scots were quite happy!MOC member since 05/97
OH the dreaded US Gallon I wondered why my maths didn't work out.Originally posted by AdminUser View PostI think you may find that an Imperial gallon of petrol weighs in at around 7 1/2 lbs or 3.4kg. None of this colonial short measurements for me - you get a fuller measure in the UK.
s!
1 gal imp water weighs 10lbs and the specific gravity of petrol is around point 7 so there you go !Ben Caswell probably not the last word on anything here!!
6LBS is 2.72 Kg for those who cant be....I could not be either so 'googled' conversion charts
