Wiring an RPM gauge
    • 2797
    Wiring an RPM gauge
    Help please, I really must get this wired in, so which wire goes where, and should the casing be earthed ?
    Google has just confused me, note that my choice of wire colour is purely arbitrary, it's what came out of the stock box
    I guess one goes on the coil or the distributor (I have a standard coil, no ballast resistor) but which terminal ?
    ......and the other ?
    The top terminal is a push on bullet type, to which I've attached a thicker white wire
    The lower terminal is a spade type and I've put a green wire on this one
    T I A DC
    • 1648
    Re: Wiring an RPM gauge
    Aha! I have just wired up one of these for my classic so you are in luck for a speedy reply!
    The spade terminal is for 12v ignition supply. The bullet connector is the sensing wire and needs to go to the Earth terminal on the coil. The panel light can be looped into the existing panel lamps feed and the clamp that holds it all in to the dash normally earths the body. If you have a wooden dash, or metal sub panel mounted to a wooden dash, then run an earth wire to a terminal under one of the clamp screws. Peter.
      • 2797
      Rapid and good info, as always.
      I've just added text to the picture above in case anyone wants to save it for reference
      Many thanks Peter
      Rgds DC
      EDIT : As at 4pm the car now has a working RPM Gauge, thank you
        • 1648
        Result!
