Wanted Front Suspension Struts
  • old_n_notpastityet
    • Apr 2015
    • 197
    Looking for Marina front struts disc brake type for my Roadster,will pay for postage or pick up if I'm near enough.P.M. me if you have any for sale. Cheers.
    Re: Wanted Front Suspension Struts
    Beware, some more unscrupulous traders have sold accident damaged uprights that are twisted usually forcing the steering arm towards the tyre from a frontal impact.
    Check the condition of the trunnions threads at the bottom of the steering upright, that usually corrode through lack of maintenance, this can be resolved with a Walford trunnion kit.
    Check the condition of the stub axles, often the bearing retaining nut gets overtightened, this can lead to bearing inner races rotating on the axle, a recent post describes this.
    Everything else is pretty simple.
      • 930
      Check the condition of the stub axles, often the beating retaining nut gets overtightened, this can lead to bearing inner races rotating on the axle, a recent post describes this.
      Yes, use a set of outside callipers to make sure that they are round.
        • Apr 2015
        • 197
        thanks for the input folk's
          Try Stuart Miles 07517 626540. He breaks Marinas
            • Apr 2015
            • 197
            cheers for the info mate.
            UPDATE.........Now found some ,thank's for all the replies
