Fiat 2.0 Twin Cam Engine oil?
  • element
    • Dec 2015
    • 288
    I'd like to change the oil in our Roadster... The Haynes manual for the Fiat 131 / 132 says it should be "SAE 15W/40 Multigrade Oil - Olio Fiat VS+ Supermultigrado" - but that was 35 years ago & although I think it is referring to mineral oil I'd prefer to take someone's experienced advice..
    If you have a Fiat engine - what current available engine oil do you put in it & where can I source an oil filter too?
    I tried joining the 'Sporting Fiats' forum to get the same advice but have had no response to my application...
    Many thanks in advance
  • AdminUser
    • 189
    Re: Fiat 2.0 Twin Cam Engine oil?
    10w40 semi synthetic should be ok. Your engine should have a number cast on the side iirc like 138? I had this engine in my Abarth Strada 130TC
    To be sure you could try here...
    • element
      • Dec 2015
      • 288
      Ok thanks for that; the link offers a wide selection of oils; not as difficult as I'd thought it'd be... I have also found the filter now:
      AE CAR Italian car spare parts for Lancia Delta HF Integrale & Evolution 2.0 8V 2.0 16V, Abarth 500 595 695, Abarth Grande Punto Abarth Punto Evo, Alfa Romeo 155 Q4, Lancia Delta HF 1600 Turbo, Fiat & Lancia Lampredi Twin Cam. Based in East Sussex BN8 6JD.
        I use 15w40 in mine. change each year with filter.
          • 1639
          If your engine has solid lifters you need oil with a high ZDDP content (Google it). For my Rover V8 I use Titan Syn MC semi synthetic, from Opie Oils. Peter.
          • element
            • Dec 2015
            • 288
            Just googled the ZDDP & it does sound good, the oil you refer to would be Fuchs Titan Syn MC semi synthetic - but its currently out of stock with Opie Oils. Says restocked in 3/5 days so I'll give them a week and try again..
              • 1639
              Originally posted by element View Post
              Just googled the ZDDP & it does sound good, the oil you refer to would be Fuchintr Titan Syn MC semi synthetic - but its currently out of stock with Opie Oils. Says restocked in 3/5 days so I'll give them a week and try again..
              Yes that's the one! Apparently the zddp content of oils was reduced to avoid messing up cats. Then they used roller lifters to avoid the wear issue which was bad news for older engines. The law of unintended consequences eh! Peter.
                • 929
                I used valvoline 20/50 racing in the Fiat twin cam that was in my rally car.
