Roll bar
    Roll bar
    Has anyone fitted a rear roll bar to their Roadster? Do you use it to carry the hood and is it bolted or welded to the chassis?
    Any pics. appreciated.
    Re: Roll bar
    Got a roll bar, Hood rests on it and is also supported on a slot-in hoop that extends forward. I did not fit it and I have no idea how it is fitted to the chassis. The seat belt upper mounts are on it as well which is neater than the standard arrangement. I should be at Stoneleigh if you want a look. (re wiring permitting!)
      Re: Roll bar
      Thanks Don, hope to be there also. Best of luck with the wireing.
      • mazzjngooglemail.com
        • 9
        Re: Roll bar
        I welded mine to the chassis and use it as the rear part of the hood frame, I have 2 tubes welded in i fit the modified front part of the hood frame into.
