Does any know where I can source the front side lights, I have one .
side lights
Re: side lights
Sidelights for?
can you post a picture of the one you have got?
A good place to start might be http://www.s-v-c.co.uk/category/lights/
Re: side lights
Hi Mike
If you still have that light I too am looking for one.Let me know if is still available and if so the postage cost to Canada and I will tranfer you the amount .
Thanks
MichaelOriginally posted by MikePeel View PostI have one sidelight you are welcome to have.Standard Marlin Roaster type.
Re: side lights
What about these?
They are aftermarket side indicator repeaters for a Range Rover. Some members have fitted them to their Cabrio. Not sure if the Roadster is the same. You could message the seller to enquire about postage to Canada. You would require bulb holders with clear bulbs aswell.
Re: side lights
These definitely look good on roadstersOriginally posted by scott h View PostWhat about these?
I too have some of the horrible rubbolites sitting in my garage somewhere if anyone wants them, plus some of the rear clusters - i may have to rummage to find them.
Re: side lights
This is where I recently got mine from, they are the originals supplied on the Roadster.. I got the amber version and use as an indicator.. see pic ..
https://www.thexmod.com/item_detail...._Pole_50/01/00IMG_2509.JPGTriumph Herald 1200 based Roadster
Re: side lights
You need to be careful on later cars if you plan to go sidelights in the headlight and indicators on the wing as after April 86 the requirement distance for the marker/side light inboard of the edge of the vehicle was decreased from 510mm to 400mm.
A Mk2 roadster is only just 400mm to the very edge of the headlight.
Also drivers of modern cars coming towards you in the dark are unaware of the fact that the car is wider than the lights they can see. I discovered this when my O/S sidelight failed and it was a very close thing!!!!Last edited by b_caswell; 21-10-17, 11:43 AM.
