Steering tie rod extenders?
  • Doublerat
    • Jun 2013
    • 35
    I have a long wheel base marina 1800 roadster and for the last MOT had to replace the track rod ends
    I have always been a bit concerned that they engage with probably only 8 or 10 threads and replacing them only reminded me of the problem (if that's what it is)
    Does anyone know of any tie rod extenders that would fit the marina set up?
    Or what the thread size is so that I can search for some
    Any help is much appreciated
    Thanks
    Phil
    Re: Steering tie rod extenders?
    Normally you would expect that thread engagement should be about 1-1.5 times the diameter.
    First check that the front uprights are not bent or distorted. This is usually spotted by a difference in the gap between the tyre and steering arm from side to side.
    You can use Classic Mini extended rack rod ends but what you have should be enough.
    • Doublerat
      • Jun 2013
      • 35
      Sorry not to have got back to you before, things have been a bit hectic here..
      I have checked and can't find any distortion, so will have to go with the extended rod ends
      Thanks for the link these should give a bit more engagement
      Didn't someone else have a rod end fail while driving because there were too few threads engaging? I seem to remember ready something on the the forum but can't find it now....
      Anyway thanks again for the help
      Phil
        Phil
        Sure somebody reported the problem. Guess what a twisted upright!
        • Doublerat
          • Jun 2013
          • 35
          Finally got around to installing the extended rod ends
          Taking a datum off the hub face the uprights don't seem to be distorted which was a relief. These were the measurements side to side:
          I am now much happier now that I have about 1.5 diameters thread engagement
          Thanks for help with this, it is much appreciated
          Phil
            Pleased there is no obvious twist in the uprights.
            I know the rod ends are longer, but not how much.
            Please tell?
            • Doublerat
              • Jun 2013
              • 35
              Because the difference was visual I never thought to measure them before fitting them, but have just whipped a wheel off and measured them as best I could:
              old rod end overall length = 87mm
              new rod end overall length = 94mm
              so extra engagement = 7mm (taking me from just shy of 1 rod diameter to a more comfortable 1.5 diameters)
              The rod ends fitted were mini competition units and acquired through a mate who races grass track and I am told that they are in fact triumph spitfire units
              I hope this makes sense
                Thanks for the effort, it was something that I neglected to record.
                I am not sure if it is mechanically significant, it was never a Marina official retro-fit, but, once you have established that there is no accident damage, and it gives further peace of mind, then it's a comparatively low cost effort.
                It is fortuitous that a Classic Mini part does indeed fit without any modification.
                But, the moral is, always check and Double (did you see what I did there) check before assuming the solution to an alleged problem.
                Thanks for the info. I hope it helps others.
