another up-date on the rebuild
  • darth vader
    • Feb 2017
    • 83
    Good evening all
    all seems to be going well with the rebuild, I am currently setting up the wiring harness all of the front suspenssion is in the radiator is ready to be mounted.
    I have decided to move the location of the battery in to the back of the car as I intend to make some sort of boot space in the very near future, the old battery space
    now been converted to a small storage box so I can carry emergency break down parts such as plugs point and odds and sods.
    I came across a small problem after the engine was fitted and the steering shaft was in place, there is no room for an air box so I have had to build a custom plenumb chamber to feed air to the carbs. I have included some pictures and the sketches if it is any use to anyone who is building a car with a Triumph engine in.20170717_211606.jpg20170721_214028.jpg20170721_214036.jpg20170721_214053.jpg20170722_140406.jpg20170722_154009.jpg20170722_165831.jpg20170722_190927.jpg20170722_195201.jpg
    At the moment I am deciding if I should keep the box as polished alloy or spray it either gloss black or metalic blue to match the engine.
    comments welcome
    Darth Vader
  • stefan64
    • Jul 2017
    • 21
    Re: another up-date on the rebuild
    Hello Mike,
    looks all very good and i think, i would do it gloss black so there is a nice effect between carburettor and the crome cooler;
    Best Regards
    Stefan64
      • 686
      Nice bit of fabrication. Another vote for gloss black.
        • 2797
        Me too
          • 930
          A vote here for polishing it.
            • 1648
            Nah! Black is for chassis, suspension and dirty bits! Blue for the magnificent engine job and keep the nice plenum alloy to match the carbs!
            If you use very fine scotchbrite with a bit of paraffin on alloy, using a circular polishing motion and then don't polish it but rinse it off with white spirit you will get a nice semi matt finish. Then spray a coat of Halford clear lacquer to preserve the effect .
            I have used that technique on bike brake levers in the past. Simples! Peter.
              • 2797
              Peter
              Thinking about KEX, is that the best idea for bonnet sides, bonnet, and doors ? I wonder if it will have a uniform look over the whole panel ?
              How long does the lacquered finish last ?
              Sorry Mike, I don't mean to hijack your thread Rgds DC
                • 930
                Originally posted by dcunn View Post
                Peter
                I'd be interested to know as well
                  • 1648
                  What is KEX?
                    • 2797
                    The next one, KEX 39N, you obviously missed the thread I started :
                    Here you can keep up to date and help support club members who are currently building or renovating their cars.
                      • 1648
                      Peter Thinking about KEX, is that the best idea for bonnet sides, bonnet, and doors ? I wonder if it will have a uniform look over the whole panel ? How long does the lacquered finish last ? Sorry Mike, I don't mean to hijack your thread Rgds DC
                      Ah yes the new project! The clear lacquer that I used on my bike lasted well out in all weathers, as it was a cellulose aerosol after all so similar to body paint. I think the matt finish of the scotchbrite gave the lacquer a good key as without primer you would perhaps expect it to flake off. It was not on a large area like a body panel but the scotchbrite application would need to be consistent to get a good finish. Why not try a test piece and see what it looks like? Peter.
                        • 2797
                        Thanks Peter, I think a large area trial is the only way as consistency may be difficult....or maybe I'll just leave it as is and go for the "patina" look
                        Rgds DC
                        • davidmartin720
                          • 188
                          One of the members of my local Kit Car Club who lives near Salisbury, has a car with a stainless body and he did uniform swirls on it and it certainly looks good. I know aluminium is softer and as Peter says needs a lacquer to protect it. David.
