Hi
my mechanic has discovered the cause of the girling fluid leak and brakes problem, it seems that the brake master cylinder leaks fluid in the brake pump.
I'm trying to find a new one on ebay but it seems impossible.
It's the higher one in the image, with the girling fluid tank.
The lower one is ok and it's the master clutch cylinder.
Can you help me please?
