MOT emissions
  • lynnx22
    • 67
    MOT emissions
    Just reading - as yer do - the 18th edition of the MOT emission requirements for the guidance of testers.
    Page 2 states that amateur and kit built vehicles registered before 01/08/98 are visual emissions only ( considered as pre 1975 )
    Did we all know that? I certainly didn,t.
    Might help.
    • 929
    Re: MOT emissions
    That's right it's just a smoke test. The last time I looked anything on a Q plate...
    • lynnx22
      • 67
      Re: MOT emissions
      Learn something new every day .......
      • scott h
        • Mar 2013
        • 670
        Re: MOT emissions
        It needs to have a Q reg to qualify for visual smoke test. One of the few advantages of a Q.
        • davidmartin720
          • 188
          Re: MOT emissions
          My 1996 Hunter before I bought it 2 years ago had only had a visual smoke test. When I took it for MOT to a different garage they failed it on emissions and front flexible brake pipes catching on wheels when turning. On retest a different Tester passed on Visual smoke test. This year the original Tester tried to fail it on emissions, but it was only after I pointed out the relevant details, ie pre 1998 he passed it. By the way mine is a "P" registration. David.
          • peterboat
            • Jun 2016
            • 232
            Re: MOT emissions
            But if your car is a Hunter, it isnt a kit, its a new car as it says on the front page of the V5C, so it should be tested for the year of manufacture.
            Mine was tested the other month and flew through because everything is present and working as it should
            • dave_clutterbuck
              • Jun 2012
              • 260
              Re: MOT emissions
              Mine is also P registration only visual test for MOT, at the last MOT out of interest it was tested on the emissions test it passed within the limits.
              • dave_clutterbuck
                • Jun 2012
                • 260
                Re: MOT emissions
                My V5 just says Marlin no reference to Hunter or Cabrio
                Two separate MOT testers have classed it as a kit car without any comment from me
                • lynnx22
                  • 67
                  Re: MOT emissions
                  In this instance, what is the relevance of a "Q" plate ?
                  A "Q" plate refers to a vehicle made from other parts and has no bearing on the date of registration per se.
                  The MOT manual only refers to date of first reg.
                  "PETROL AND GAS POWERED VEHICLES
                  Vehicles to be tested
                  In-use exhaust emissions testing is applied to all petrol and gas-powered vehicles with four or more wheels. The test does not apply to vehicles fitted with 2-stroke engines. The following types of vehicle will be considered as first used before 1 August 1975 (Visual Test):
                   Wankel rotary engined vehicles first used before 1 August 1987.
                   All kit-cars and amateur built vehicles first used before 1 August 1998.
                  1.1 Types of test
                  The emissions test to which a vehicle is subject will depend upon its date of first use (i.e. date of registration or date of manufacture if used abroad before first registration in the UK) as follows:
                   For vehicles first used before 1 August 1975 a visual test will be applied.
                   For vehicles first used on or after 1 August 1975 a metered test will be applied."
                    • 709
                    Re: MOT emissions
                    For emissions purposes a Q plate (i.e. uncertain age) is deemed to be pre-August 1975, hence visual smoke test only...at least that's my understanding..!
                      • 929
                      Re: MOT emissions
                      Mine too.
                      • lynnx22
                        • 67
                        Re: MOT emissions
                        No wonder the MOT guys are "confused.
                        "3. Vehicle ‘first used’ Dates - Application of Test Criteria
                        NT’s will normally be provided with the vehicle details as part of the registration process. This will usually include the vehicle’s ‘first used’ date. Where this information is available, the NT should only use Reasons for Rejection applicable to the vehicle’s age.
                        However, in cases where this information is not available or incorrect, the NT should determine the vehicle’s ‘first used’ date as follows:
                        a. Its date of manufacture, if the vehicle was originally used without being registered in GB (e.g., an imported vehicle or ex-HM Forces vehicle), or
                        b. Vehicles having a Q plate registration when presented for MOT are to be treated as follows: For emission purposes only, all these types are to be considered as vehicles first used before 1 August 1975. For all other testing purposes they are to be considered as being first used on 1 January 1971" (MOT Inspection Manual 2017)
                        So now we have 3 variants -
                        a) The amateur and kit built dates.
                        b) The Q plate dates.
                        and
                        c) The engine manufacture dates!
                        Worth knowing all of these to be able to quote come the time lol!
                        • peterboat
                          • Jun 2016
                          • 232
                          Re: MOT emissions
                          Mine just says Marlin, but section 3 on the front page says declared new and these notes cant be removed, so for me its tested as a 1997 car as the running gear was all new when installed.
                          • dave_clutterbuck
                            • Jun 2012
                            • 260
                            Re: MOT emissions
                            Indeed my section 3 does say that I had not noticed before, as the engine pre dates the car it has to be emission tested to that date for me
                              • 903
                              Re: MOT emissions
                              I actually wanted my MoT chap to carry out the emission test. It helps me know how my own modified Bosch L-jetronic system is working.
                              He agreed a the report was well within limits.
