Jrr 929 d
  • A_Hogg
    • 338
    #106
    Re: Jrr 929 d
    Just get them powder coated with the wheels. Can't imagine that it will cost much more.
      Re: Jrr 929 d
      Will powder coating survive the high temperature of brakes?
      Will it affect the heat dissipation of the drums?
      • Ye Ol Ripper
        • May 2016
        • 298
        #108
        Re: Jrr 929 d
        Hi David
        The rear drums don't get that hot unless you over adjust them and then that will cause the wheel cylinders to leak. I painted mine in gloss black from Toolstation at the time it was paint made by Flag. No flaking or peeling evident so far
        If you really want a heat proof paint then you could use a tin of matt black log stove enamel , Toolstation sell it in aerosols . No primer needed with that paint , just remove as much of the rust with rotary wire brushes used in corded drills. The drum can then be placed in the oven to cure the paint.
        • djj_engineer
          • 405
          #109
          Re: Jrr 929 d
          Hi David
          I'm curious why you should want to paint the rear drums black when the front discs are shiny.
          Also the original cushions went with the car when it left North Wales. I have no info where they went afterwards ( or what was done to the car)
            Re: Jrr 929 d
            Hi Derek,
            Only because they are rusting, visible through they wheels and a wire brush didn’t easily get them shiny again. I’ve done them in satin black hammerite which I had in the garage.
            The seat cushions are covered in some black leather covers from another vehicle and are fine for now. Maybe the foam cushions are the originals, no easy way to tell! Paul M does recall them being fabric covered though.
            • djj_engineer
              • 405
              #111
              Re: Jrr 929 d
              Hi David
              I changed the rear drums for new ones after I found the others were not round! I didn't paint them cos I had lost interest in the car by then.
              I created the seat covers from a RR back seat but I could not get out off the car with the steering wheel in position hence to removable steering.
              But I found that sitting on the wooden seat was a better driving position.
                Re: Jrr 929 d
                So those seat covers are probably the most expensive part of the car!
                The removable steering wheel fitting was not on the car when I got it. It had a Moto-lita three spoke flat wood rim which I have just changed for a slightly dished version in black to bring the wheel closer to me, matching the overdrive Spitfire gearstick (hollow so the wires can go through it) I put in which is angled back slightly more.
                Both mods take them a bit further away from the dashboard controls which is nice especially on the steering wheel which is now in a position more like the small leather rimmed item the car had on it when you acquired it. The tonneau cover still fits OK, why we call these covers that in two seaters I don't know! :-)
                  #113
                  Re: Jrr 929 d
                  The word tonneau is French, meaning 'cask' or a large barrel like container made of wood, metal, or plastic, used for storing liquids, typically alcoholic drinks. ... A tonneau cover describes the device to cover up and protect whatever is stored in the tonneau - passengers in a car or cargo in a truck or pickup truck.
                    Re: Jrr 929 d
                    Quote "So those seat covers are probably the most expensive part of the car!"
                    Is THAT RR= Rolls Royce or more likely RR= Range Rover??
                    I know where my money is!!
                      Re: Jrr 929 d
                      Ah, good point
                        Re: Jrr 929 d
                        The cockpit is looking nice and period, I like it. I do like the look of the seats, if they are as comfy as they look good the you're on a winner........ I have a pair of MX5 Mk1 seats to crowbar into my Cabrio over the winter, hope I can achieve something that looks as good. For general info, MX5 seats are a well known swap in the TVR fraternity (I sold my TVR in Feb after owning a Chimaera for 8 years, I found that when I was choosing a car to take out I was always choosing the Cabrio) as they are just such comfortable seats, sadly the base is a tad wide but with a little persuasion they should fit.
                          Re: Jrr 929 d
                          Thank, the seats are comfy just the trim detail on and around the rear upright is bad so trying to find a local trimmer to tidy them up as my efforts will not improve them!
                            #118
                            Re: Jrr 929 d
                            Hi David
                            Try this guy, he's good and fairly local
                            www.ajtrimming.co uk
                            Used him for the Zip in my tonnau.
                              Re: Jrr 929 d
                              I’ve tried to get him a few times, no response..
                                Re: Jrr 929 d
                                Engine & Gearbox
                                Right, I'm gearing up, pun intended, to refurbish the engine and gearbox. The car appears to have a Vitesse MK1 2ltr with overdrive box.
                                First quote I have from a local reputable restorer is £8k of which the large amounts are £2800 is for the engine refurb and £2000 is for labour.
                                I'm not looking for a long debate on saving a few quid here and there but are these numbers in the ball park in anyones experience?
                                An option is to swap in a cheap used motor (probably a MK2 as they are more plentiful etc) but that means we loose the 'matching numbers' of chassis and engine the car currently enjoys. Is this an issue for tis car, should I try and keep the original engine?
                                I did wonder about setting up a crowd funding page to help with the cost as this car is an historical asset for the club but that feels a bit odd given I own the car!
                                Thanks,
                                David.
