Hi, I took my Hunter out this morning (first time for a month) and drove c.10 miles (15-20 mins), stopped for c.10 mins with the engine running and then headed back home. After about 2 miles I felt the car losing power and then the engine cut out. The engine turned over, but would not start. As it happened, I was about 100 yards from a garage I use, so pushed the car to the garage. The mechanic came out, sat in the car and with some hefty use of the accelerator the car started pretty much immediately. The engine was now running smoothly. I'm feeling a bit stupid!
So, I thought I'd try to get home. After about a mile exactly the same thing happened, loss of power, engine cutting out and I just managed to pull into a lay-by. I then tried to start the engine - no luck. So, I called the break-down service I use. After about a half hour and just before the truck arrived, I decided to put the key in the ignition and standing outside the car (i.e. no use of the accelerator) I turned the key and the engine started immediately. So, I drove the car onto the truck, got taken back to the garage, drove off the truck and into the garage! Feeling even more stupid!!
My Hunter has a 2.3l Ford engine and is an automatic.
Obvious thoughts are fuel issues (old fuel, fuel pumps, condensation on cold morning etc) and electrics. The garage have had the car on the ramp - nothing obviously wrong and have run the engine for well over an hour with no issues. My car has 2 fuel pumps - is this normal - think I've heard of this before - I think when I had some work done on it 10 years ago or so?
I've never had this happen to me before. I'm assuming there's no diagnostics hook-up (the garage can't find one) and Terry at Marlin appears to confirm this. I'm waiting to speak to the workshop at Marlin to see if they can help at all.
Has anyone had something like this happen to them? I'd be grateful for any thoughts.
John
John
