Hi folks,
I'm making good progress with my A series Roadster, finally sorted the very lean SU after studying SU needle books, charts and wonderful programs on the Web that I couldn't use. Finally contacted the SU Guru at Minispares and he gave me a couple of options. Going with his "hunch". It was an original 77 Waxstat job with a standard ADG needle. Changed this to the recommended one and Robert is indeed your Auntie and off it went. Instant starting, faultless mid range and after setting up the Jet height, it idles well.
New gearbox is in and I think its now as good as its going to get. At least it doesn't need the gear lever to be held in reverse any more and 1st is "bang" free!
Next thing is what to do about the wheels. I have original "Comics" fitted which are well tatty and require a refurb. There are a couple of good recommended refurbishers up here in North Aberdeenshire and it will work out at around £50 per wheel. The wheels are shod with 13" rubber at 165 X 13 etc. Standard Goodyears and almost worn out.
Can any of you advise whether it may be a good idea to purchase some new wheels? I notice Minilites are available at around £80 and I thought that seen as I need new rubber would it be an ice to go for 14 or 15 inch wheels? Bearing in mind I'm on the standard gearing and 60 mph has the wee motor revving hard, would a change of wheel size help out bearing in mind mudguard clearance etc. What set up have you found to work well or be the best compromise?
Thanks
Scotty
Thanks
Scotty
