My 1984 Mk2 Roadster for sale.
1275 Marina based. Registered as a Marlin Roadster Mk 2.
1984 Build.
Owned and steadily improved during my 3 years of ownership. I've spent a fortune and significant improvements include an new Earlpart gearbox. So no longer jumps out of reverse etc. Nice slick change and is just perfect. New HS4 fitted and extensive research and trials to find correct jet. Correctly tuned and full electronic ignition ignition and new distributer compliments it. It now runs perfectly. Full brake service with new pads and shoes and handbrake cable. All correctly set and adjusted. Many new parts fitted and a couple of boxes of useful new spares.
New sump sourced and fitted to the Gold Seal A series and new valve seals and valves ground. Runs and sounds perfect. Full Mot obtained mid March- no advisories.
Comes with a hardly used soft top and a tonneau cockpit cover. Fully serviced with all new coolant and oils.
Offered firstly to the classified section of the club before trying eBay.
Happy to deliver anywhere in the UK for cost, but suggest you view and test drive firstly. Car is located in N Aberdeenshire.
Thanks
£2750 firm.
scottymcb3@gmail.com
07766 727924
1984 Build.
Thanks
£2750 firm.
07766 727924
