Help with BMW electronics
  • duncan
    • Apr 2018
    • 137
    Hi Guys
    I have just acquired a Marlin Roadster Mk2 - the Marina one
    That had been started in 1995 - and stopped soon afterwards
    I have managed to squeeze a 1992 BMW 318i engine and auto gearbox into the space
    BUT - last time I did this sort of thing was in the days of carburettors - this unit has electronic injection and far too many wires going into the gearbox
    Is there anybody on the forum who can help me with identifying which wires and things I NEED and which I can throw away?
    Incidentally I'm in New Zealand - when I get this on the road I believe it will be the second Marlin here
    • 2792
    Re: Help with BMW electronics
    Welcome Duncan. I cannot help you with BMW info but as archivist I would like to know the chassis/kit number of
    your car and I'm sure the guys on here would love to see some pics of your shoehorn job
    Email me direct if you wish, my details are in Pitstop
    Best Wishes Dave Cunnington
    • duncan
      • Apr 2018
      • 137
      Is the number on the Chassis somewhere?
      I haven't seen it yet - I will have a look in the paperwork that accompanied it and see what is there
        Should be on plate located on left hand front chassis leg forward of suspension lower arm.
          • 2792
          Like this
            Presume you are using engine wiring loom /ecu etc from the BMW ?
            • duncan
              • Apr 2018
              • 137
              Yes
              I have everything from the donor car - had to cut the loom in a couple of places (well I thought that I had to) - unfortunately there are lots of wires the same colour! so simply repairing the cuts is not as easy as I expected
              • duncan
                • Apr 2018
                • 137
                Found the plate - painted over with a good thick layer
                I assume the numbers are stamped into the metal - I'll get some solvent/thinners and see if I can make them out
                • duncan
                  • Apr 2018
                  • 137
                  Ok
                  Kit number and Chassis Number are both the same
                  20-1075-C
                  Collected - 8/4/95
                    • 2792
                    Many thanks Duncan
                    We shall be watching your progress with great interest
                    Rgds DC
                      I'm not envious of those facility's ---not much!!!!!!!!!!!!!!!
                      The engine/box install looks neat too.
                        • 2792
                        Duncan, just a thought but looking at your bonnet height tube, it may be a little high at screen level.
                        Here's a pic showing that the bonnet will be a bit lower, perhaps you would like to try
                        putting the front part of the screen holder in place to give you a truer dimension ?
                        No offence meant , but better to check now before you have the engine mounted !
                        If you have a one piece bonnet top, a bulge could always be manufactured anyway
                        Rgds DC
                          He aynt got the front piece see his wanted post
                          "Hi
                          I have just acquired an old never completed Roadster - Mk2 - Marina version
                          I have the fiberglass "scuttle" that is behind the windscreen - the dash goes into this
                          But I don't have the fiberglass part that is in front of the screen
                          I will probably have to make one - I'm in New Zealand
                          But some nice pictures showing what it's meant to look like would help
                          Thanks
                            • 2792
                            Duncan, sorry didn't know you're short of that piece !
                            Here are some pics to help
                            If you like to email me personally I will send high res copies and also look for more
                            Someone somewhere in UK must have one - can anyone remember contacts for Rob who was selling parts a month or two back
                            Rgds DC
                            • meverett
                              • 662
                              I have a spare one. Dread to think how much it would cost to send to New Zealand though.
                              I will take some pics as well later.
