Roadster Hybrid
    Re: Roadster Hybrid
    The petrol tank will be from a Ford Escort Mk2 estate or van so beware that the car will probably run out
    of fuel when the gauge says about a quarter of a tank. Unless someone has tweaked the sender.
    Not sure what the switch on the right would be but if your going for a full rewire I would also have a rethink
    with the dashboard at the same time. Would pay to get a Haynes manual for the Vitesse/GT6
    The gearshift will be standard H same as the Herald reverse is press-down and left then forward, somewhere there would be a simple switch for the overdrive.
    • letsgrow
      • May 2017
      • 16
      Re: Roadster Hybrid
      Cheers Ben ,
      Yes to dash layout, it’s awful ! I’m surprised the tank is from an escort. On the wiring front Ill go down the road of making a loom or try find a generic kit with modern fuse board etc. Will dig through Gallery for nice dash layout. Main objective is to get things running as is and give a light test run before stripping everything apart. I learned this the hard way over the years, haste makes waste.
      All the best, T
      • meverett
        • 662
        Re: Roadster Hybrid
        Hi Trevor,
        I am also on wiring and undecided to whether use and adapt the original loom, figure out and create my own loom with only wires that are used or buy a generic loom. Be interested which you decide to do.
        A question about the roll over bar, could you upload a picture of how it is mounted please as that is another mod I am considering.
        The fuel tank is from a mk2 escort van or estate, quite rare now and worth a bit for a decent one.
        Cheers, Martin.
          • 2796
          Re: Roadster Hybrid
          Martin and Trevor
          I have used modified Marina looms - look at : http://www.marlinownersclub.com/foru...iring+diagrams
          E mail me if you would like e copies of the diagrams I have produced
          ....and Trevor please tell me what the old Irish plate number was, good to note should any old pics ever turn up
          Rgds DC
          • letsgrow
            • May 2017
            • 16
            #20
            Re: Roadster Hybrid
            Hello All,
            Will post pic of stainless roll bar. I think it was meant to be part of a boot/tyre rack and some of its missing. I have a hood but no frame for it so not quite sure how well placed it is as yet. It’s not strong enough for a roll bar IMO. I did see a trial car with one fitted further back of box steel. Wiring, well I have more home work to do per link from DC ?????? Oh the Irish Plate I found in that very spot. My have been the donor Vitesse.
            Thanks, T
            • letsgrow
              • May 2017
              • 16
              #21
              Re: Roadster Hybrid
              Disregard ???? Was meant to be an emoji
                • 2796
                #22
                Re: Roadster Hybrid
                Just a thought Trevor, the electrickery mentioned is Marina, and you have a Vitesse donor ? Are you using Marina or Triumph wiring ?
                I'll have a look at my records for the Herald based car I rebuilt to see if I did the same thing, it may be better for you ?
                Here you can keep up to date and help support club members who are currently building or renovating their cars.
                Rgds DC
                Edit : Sorry, no, nothing found. Guess I must have just used the Haynes/Triumph manuals and hooked up the wires that way
                • letsgrow
                  • May 2017
                  • 16
                  #23
                  Re: Roadster Hybrid
                  Side shot of how part of rack is mounted. Welding not great and would not rely on it as a roll bar .
                  • meverett
                    • 662
                    #24
                    Re: Roadster Hybrid
                    I recently visited someone that is keen on trialing and got a couple of pics to give me an idea for a roll bar but the same welding not great.
                    Just need to find someone that can bend the tubing so I can tack in place then take to a professional welder.
                    • Lanciajohn
                      • Sep 2015
                      • 38
                      #25
                      Re: Roadster Hybrid
                      try tube bender on ebay just put roll cage into ebay search they will bend cds tubing to your diagram for very reasonable price. I used then for the main hoops for rally cars they were always very professional.
                      • meverett
                        • 662
                        #26
                        Re: Roadster Hybrid
                        Thanks for that, think I have found them, £14.95 per bend and just over £50 for the 50mm tubing, sounds reasonable as I would only need 2 bends
                        • Lanciajohn
                          • Sep 2015
                          • 38
                          #27
                          Re: Roadster Hybrid
                          tube bender roll hoop complete £79
                          • meverett
                            • 662
                            #28
                            Re: Roadster Hybrid
                            Thanks, that’s cheaper, will measure up.
                            Cheers,
                            • letsgrow
                              • May 2017
                              • 16
                              #29
                              Re: Roadster Hybrid
                              Great Wall art in background....
