Which radiator is this?
  • meverett
    • 662
    I’m not yet ready to fit and plumb in the radiator yet.
    Just thought I’d get some info on what I have.
    I thought it is from a mini but I am sure others will know.
    When I stripped the car it did show signs of overheating but that may have been down to the rest of the cooling system of which has been completely flushed as was this rad then a couple of coats of paint.
    The core measures H=295mm W=280mm and the overall height to the filler is 380mm.
    Cheers, Martin.
  • phild
    • 128
    Re: Which radiator is this?
    Sorry Martin,
    No idea, about the right size for a mini what diameter are the hose joints? They look about 28 mm from the photo. Search original mini rad on ebay and see if the photos and dimensions match.
    cheers phil
    • meverett
      • 662
      Thanks Phil,
      The hose joints are 26mm the same as the water pump and thermostat housing on my A series.
      Looking at the dimensions I think it is a classic mini rad.
      As it showed signs of over heating before I stripped the car I may replace with an aluminium 3 core and upgrade to an electric fan.
      The original water pump fan probably added to the overheating as well.
      Cheers, Martin.
