Anyone else noticed the web site clock is an hour slow?
the web site clock
Tags: None
Re: the web site clock
It’s been GMT +2 for a while now. Which makes it fine for me in Spain.
Posted at 12:53 Spanish time.MOC member since 05/97
Sounds like it might be a job for web admin. If anybody can tell me how to do it I will “make it so”.
Of much more concern, to me, is that nobody has volunteered to do my job after May. It might happen that the clocks will stop altogether very soon.
Figured it out; DST (daylight savings time) is a member option.
When logged in select settings at the top right.
Under My Settings – select general settings
Under “date and time options”
You can select Time zone – This will be London for most members but could also be Paris for those in Spain. Other countries are available.
DST correction option – I changed this to “automatically detect DST settings” it was “DST corrections always off” always on is a third option.
Click save changes.
You need to log out and in again to activate the change.
Well done that man! I think I will leave it as it is
Originally posted by mocad2016 View PostFigured it out; DST (daylight savings time) is a member option.
Click save changes.
