Header Tank
  • A_King
    • 18
    Header Tank
    Hi Guys. Does anyone have a radiator header tank on their DOHC 8V 2ltr. If so where is it located please - a photo would be great. When we returned from Stoneleigh I noticed that water was dripping from the radiator overflow pipe. Thanks
  • dave_clutterbuck
    • Jun 2012
    • 260
    Re: Header Tank
    From the front of the car mine is on the right hand side of the bulkhead just to the right of the battery
    Is your radiator single core ?, mine is and does overheat on occasions Coolex in Nottingham are doing a double core one for me now using the original housing and brackets
    Dave
      Re: Header Tank
      It all depends on who built the car.
      My header is a metro item mounted on the N/S bulkhead.
      I did initially have a problem with water loss because I had fitted a conventional filler in the top hose, but it vented through that before venting through the metro header tank. My radiator is a Marlin supplied item and worked fine when I had a DOHC engine fitted.
      • stewartdjones
        • 86
        Re: Header Tank
        Hi,
        Here is a pic showing the header tank I have fitted to my Cabrio
        Hope it helps
        • A_King
          • 18
          Re: Header Tank
          Thanks guys. Will try and make something up
          • mike woodley
            • 121
            Re: Header Tank
            Hi, just for clarity, the header tank in the photo is from a Rover SD1 V8. I have had three over the years, and used one for my own Marlin V8 Cabrio build. The part is available from Rimmer bros ARH259 at a staggering £99. Hope this helps. Regards Mike.
              Re: Header Tank
              That looks exactly the same as the Marina one.
              Have you browsed "Radiator header tank" on eBay, there are loads at reasonable prices including some nice alloy ones.
                Re: Header Tank
                Or try "Expansion Tank" on eBay in the cars section.
                • meverett
                  • 662
                  Re: Header Tank
                  One-stop shop for Kit Car and Classic Car Parts, Kit Car repairs and painting. Tools and Accessories for the Kit Car and Classic Car Enthusiast.
                  They have some nice alloy ones.
