Wheel studs
    • 2447
    Wheel studs
    Hi
    Anyone got a set of 4 rear wheel studs for a Mk2 Marina based Roadster.
    3/8 UNF I believe?
    Re: Wheel studs
    I can’t help feeling that wheel studs are one of those items you ought to get new. They are a press fit and will inevitably not be as tight in a second hole. You should also be aware of the stud length, especially if fitting alloys. I know that Ford studs are readily available in a range of lengths. I’m not so familiar with Marina parts but hopefully someone on this forum will be.
    • philcoyle
      • 379
      Re: Wheel studs
      check out https://www.mistertee.co.uk/ never let me down.
      • scott h
        • Mar 2013
        • 670
        Re: Wheel studs
        I'm also not familiar with Marina parts, but I know that Ford studs are available with oversize splines to ensure a tight fit.
          • 2447
          Re: Wheel studs
          Will give them a bell.
            • 2447
            Re: Wheel studs
            Good advice.
