I have what I believe is a Cortina radiator in my car (Millie). Since fitting the new engine (new somehow becoming 13 years old) I’ve had a niggling problem in that when running hot, water occasionally comes out of the rad overflow. The set up has an expansion tank fitted with a Ford Sierra, Focus, etc expansion cap but retains the expansion cap on the radiator. It’s not been a big problem so I’ve not dedicated any time to it. Now I come to look at it the problem is obvious the Cortina cap is set to 13lbs while the later Fords use 18lbs so of course the water is pushed out of the rad cap before venting the expansion tank cap. An easy fix for this was to fit a racing style cap rated at 21 to 25lbs.
The worry is; can the rad take the increase from 13 to 18lbs pressure? Does anybody have any experience of running Cortina radiators at higher pressure?
I’ve had a couple of outings in this hot weather, parking up to get the rad fan running, and so far so good.
