buch
  • kolmershlagjp
    • Dec 2015
    • 180
    buch
    Hello
    I am looking for the bush of this piece
    I do not know his name I found the others
    thank you
    Re: buch
    I would have thought it was from a classic mini as that is the mini top hat.
    Originally posted by kolmershlagjp View Post
    Hello
    thank you
      Re: buch
      I think the top arm is from a classic mini and its a shaft with bearings
      • philcoyle
        • 379
        Re: buch
        Correct, as an apprentice mechanic in the 60s I changed many.
        • duncan
          • Apr 2018
          • 137
          Re: buch
          Really?
          As a mini fan from the 70's through the 80's with lots of mini's that was about the only part I didn't have to change!
            Re: buch
            That's the puppy
            https://www.ebay.co.uk/i/172740656298?chn=ps
            • kolmershlagjp
              • Dec 2015
              • 180
              Re: buch
              I am looking for the superflex of this piece
                Re: buch
                Not a mini expert but it has similarities to an MGA and looks like you mean the rubbere grease seal cap is missing as the bush and the spindle will be a bronze and steel. I am sure if I am wrong the epxerts will advise
                  Re: buch
                  There are no Superflex part for the Mini top arm. If there were, I would have listed them.
                  If you have excessive movement forwards and backwards it is a known problem here or there.
                  Even new parts may not reduce the movement, I machined some to limit the movement.
                    Re: buch
                    If there is play in the top swivel the repair kit comes with a haft and needle roller bearings. Check the forum for removing the old bearings, they can be difficult.
                      Re: buch
                      I think you mean shaft!
                      The problem is that, in my experience, if you read the article from keepandshare, that was published in Pitstop, is that the manufacturing tolerances are variable to say the least, the reason I ended up machining my own parts to get rid of unnaceptable end float.
                      I have found no information in Classic Mini manuals or forums that specify an ideal end float.
                      Getting the old bearings out, can be a pain if the Upper Arms have not been lubricated regularly. A decent mechanic/engineer should have a Blind Hole Bearing Puller here or there that can make the job really quick, expensive for a one off job, but to do the job properly you would pull all 4, from both left and right Upper Arms, so maybe not so expensive considering the time and hassle saved.
                      There are a few DIY methods if you have a welder, to files and hacksaws etc. But they will take a lot more time.
                      • kolmershlagjp
                        • Dec 2015
                        • 180
                        Re: buch
                        can you tell me if these marina products are of good quality
                        thank you for all these answers
                          Re: buch
                          https://www.autocraze.co.uk/catalogs...=Morris+marina
                          Never heard of them before.
