Morris Marina 1.3 engine sump
    • 2447
    Hi All
    Does anyone have a engine sump for a 1.3 morris marina engine?
  • meverett
    • 662
    Re: Morris Marina 1.3 engine sump
    That took some damage too. It does sit lower that the chassis so suppose it is vulnerable.
    How much damage in total?
      • 1639
      Hi All
      If it has had a good whack check the engine and gearbox mountings haven’t split.
      Not familiar with that engine but also check no damage to oil pick up pipe, filter or oil pump. Peter.
        • 2447
        Not looked myself at the moment but it is supposed to have a split in it.
          • 2447
          Will do.
            any good?
            Blast, just seen it's gone
              Is it alloy or steel? Will it press out and weld up?
                • 2447
                Hiya
                Was thinking that just thought less hassle and quicker would be to replace it.
                Now finding that they are fairly rare, so will look at it first and maybe take it to a bloke I know called metal micky.
                  Would it be the same as this one
                    That's the one I was looking at in #6 above. Been relisted.
                      • 2447
                      Will this fit the 1275 a+ engine ?
                      • meverett
                        • 662
                        I think the A+ used a rubber seal gasket each end (flywheel and pulley) , the A used cork gaskets. Don’t think the block is different so should fit.
                        It is steel so could be welded.
