Berli Seats
  • paulratcliffe
    • May 2016
    • 7
    Berli Seats
    I have Cobra seats in my Berli which have a few tears and due for replacement. The Cobra race seats are uncomfortable and I have been looking for an alternative. They are very narrow at only 42cm across the seat and nothing wider will fit. I have looked at S2000, Fiat 500, MGF, Mini and a few more only to find they are too wide. Any suggestions?
    Re: Berli Seats
    Suzuki Cappucino seats have been used by some Cabrio owners, they will probably need a retrim though if you can find a pair.
    David Siddals modified a pair of MX5 seats for his Sportster but again a retrim is required. Depends on how much work you are prepared for, but may not be the cheapest option .
    Maybe Westfield have something suitable? Richfield or Intatrim are 2 others that spring to mind if still in business. Hope that helps.
      Re: Berli Seats
      I've got Westfield seats in my Roadster, they're 42cm. Have them fitted to the origional runners.Find the comfortable on a long run.
        Re: Berli Seats
        Have a look at GSM Performance website.
          Re: Berli Seats
          Does anyone know David Siddals email? I have a pair of MK1 MX-5 seats to modify for my Cabrio, however if David has already been through the process he may well have some useful ideas around this.
          Neil (aka Wiggie)
          • mocad2016
            • 111
            Re: Berli Seats
            Originally posted by wiggiesworld View Post
            Does anyone know David Siddals email? <snip>
            Neil (aka Wiggie)
            Hi Wiggie,
            I can’t give out anybody’s email but I can send David your contact details and ask him to contact you. Please send me a PM request.
            • copperleaves11
              • 328
              Re: Berli Seats
              Wiggie. If you wish to contact me , my details are in Pitstop (Peak District meet, Sheldon). I chose MX5 seats because I had a ride in a Sportster fitted with the same and was impressed. However after acquiring a pair I found that because my car is a short wheelbase there was no rearward movement available unlike the ones in the other car which was a long w/base. I stripped the seats down to the frames and took 1.5 inches out of the width using the strips of metal removed to spot weld the two halves together again. By cutting the same amount out of the foam filling and having them recovered I've ended up with seats that for me are very comfortable, even over long distances.David
                Re: Berli Seats
                Fortunately my Cabrio is a LWB....... Thanks for the advice, I have a friendly welder and trimmer I can call on, now where's my angle grinder.......
