DOHC 8V cutting out on over run.
    Sorry didnt remember name. Cabrio with over run cutting out engine.
    I spoke to my ex ford man who knows.Its a common problem with this engine. He said throw it away and get a proper engine.Try the following:-
    1 Ensure throttle body is cleaner than clean.
    2 " Shut off valve is clean
    3 Have the management unit reset.
    4 The throttle sensor may be playing up.
    5 A bodge that works is to drill a 1 or 1.5 mm hole in the throttle butterfly.
