Radiator grill wire
  • kolmershlagjp
    • Dec 2015
    • 180
    Radiator grill wire
    Hello
    I am looking for Radiator grill wire already made
    thank you
    • 2445
    Re: Radiator grill wire
    I have one that is not made.
    Originally posted by kolmershlagjp View Post
    Hello
    thank you
      • 2445
      Oh forgot to add I also have the wooden block pre-drilled to make grill.
      • kolmershlagjp
        • Dec 2015
        • 180
        is it all finished with the metal outline
        • Blue Marlin
          • Mar 2015
          • 314
          I have one that requires a little TLC. You can have it for postage cost. If you are interested I can dig it out and take some photos.
          Stumbling around in the dark
          Marina based SWB roadster
            • 2445
            Mine has a separate set of wires in a buddle as supplied by Marlin, a surround in the correct shape and a wooden base so that you can platt the wires.
            I hope that helps.
            • kolmershlagjp
              • Dec 2015
              • 180
              yes, I want to see some pictures
              what does TLC mean?
              • Blue Marlin
                • Mar 2015
                • 314
                Tender Loving Care
                A little work to restore.
                • kolmershlagjp
                  • Dec 2015
                  • 180
                  ok I understand I want pictures thank you
                  • Blue Marlin
                    • Mar 2015
                    • 314
                    • 928cdu
                      • 230
                      I remember spraying mine with a silver enamel rattle can (aerosol) when it started to look old. Lot of wasted paint obviously but result was ok ! They're not easy things to polish up.
                        • 2445
                        Frame with wire and instructions
                        • kolmershlagjp
                          • Dec 2015
                          • 180
                          Hello
                          listerjp blue marlin i sent you a pm
