Can anyone recommend tyres for 13" wheels on a LWB? I need to replace some ancient 185/70-13's & want a wider, sticky tyre. Falken do a 205/60-13 which might fit, but I'd lose about 13mm ride height. Web search suggests veery little choice.
Tyres for 13" wheels
Tags: None
Re: Tyres for 13" wheels
You can get Toyo Proxys in 185/60/13 or in 205/60/13. these are ment to be better than yokohama A008's where in the 90's.
The diffrence in the sidewall profile between a 185/70/13's and 205/60/13's is only 3.25mm if my maths is correct, so you wouldn't notice the diffrence in ridehight.
the toyo website is
http://www.toyo.co.uk/page.php?identity=r888
Message originally posted by: Lee
Tony
I have recently changed to a 15" wheel with a 185/55/15 tyre and there is a big difference in road holding compared to my old 185/70/13 cosmic ribster wheels's
Thanks for the advice - I had thought about changing to 15" wheels but will probably try the Toyo's first.
