Fuel pump for mk2 1300 a series
    Re: Fuel pump for mk2 1300 a series
    Hi all
    Spoke with Burlan again and an old timer who's worked there for some 30 years or more told me that the AZX 1818 will work as the only difference is the orientation of the inlet and outlet.
    For the benefit of others, who may not recognise names, Burlan, is in fact Burlen. http://burlen.co.uk/ the parent company of SU carb http://sucarb.co.uk , the experts!
      • 2445
      Apologies for my dislexia I do rely on predictive text a lot and sometimes the computer has a mind of its own.
      Of course the company name is Burlen and whether you put Burlen or SU into Google you will get the same page.
      For the benefit of others, who may not recognise names, Burlan, is in fact Burlen. http://burlen.co.uk/ the parent company of SU carb ahttp://sucarb.co.uk , the experts!
        • 2445
        OK, it's been a little while since I put the new fuel pump in and I can now report that it works fine.
        Job done and worth noting if you are in the market for a new fuel pump for your A Series engine.
          Well done, Im just about to replace the (one broken) rubber bobbin mounts on JRR's Facet pump... I may remove the original mechanical pump as well, although maybe that's handy left in place as a backup!
          Whoops, I should start that new thread now!
          • meverett
            • 662
            #20
            Nice one Adrian, I may be referring to this thread when I finally get to start mine as I don’t know the condition of the fuel pump.
            • Ye Ol Ripper
              • May 2016
              • 294
              #21
              David
              you may be able to superglue the torn rubber(Metalastic) mount.
              Failing that, the mounts are available from Terry (The UK importer of most fuel pumps and other associated parts).
              His Contact details are:
                Thanks for that, got some ordered now.
