Drive shafts
  • stewartdjones
    • 86
    Drive shafts
    My kit (Marlin Cabrio LWB) is based on a Sierra 2l GLSi fitted with discs all round, looking for somewhere where I can get the drive shafts reconditioned or new ones, all ideas out there
  • scott h
    • Mar 2013
    • 670
    Re: Drive shafts
    I got Sierra drive shafts and CV joints from this company on ebay. Beware that there are at least four different lengths of shaft (Granada are similar but slightly longer, also left and right differ in length). There are also push in or bolt on CV joints. Scott.
      • 1648
      Re: Drive shafts
      Originally posted by scott h View Post
      https://rover.ebay.com/rover/0/0/0?m...2F132213135653
      Also be aware that the bolt on Lobro Sierra ones are 100mm diameter whereas the cosworth are 108mm!
        Re: Drive shafts
        I also bought complete shafts from the same company as Scott for my last Cabrio . Good price and the quality seemed to be ok.
        As already stated be sure to get the right lengths.
        • stewartdjones
          • 86
          Re: Drive shafts
          How do measure to get the correct length?
          • burnside
            • Sep 2017
            • 97
            Re: Drive shafts
            CPS- Drive link in Gateshead make _drive shafts in the UK and also sell imported Chinese shafts similar to those sold on E Bay
            • scott h
              • Mar 2013
              • 670
              Re: Drive shafts
              You will probably find that the shafts are fine and any wear is in the joints themselves. So I would suggest that you remove the shafts from the car and dismantle them. Then you can check the shafts for wear, and if you still want new ones you can measure them. I made the mistake of assuming that if I purchased complete shafts and joints it would save me faffing about assembling them, but they arrived as a kit. So with hindsight I would have only purchased joints and boots. Scott.
              • geoff b
                • May 2017
                • 18
                Re: Drive shafts
                Hi, a recent MOT revealed that the CV gaiters on my Cabrio are showing signs of failure, although the CVs are probably OK.
                Has anyone had experience of fitting new gaiters without dismantling the shafts? The adverts suggest it is possible, but it doesn't look easy.
                • billjackson54
                  • 212
                  Re: Drive shafts
                  You could always try sierrasrus.co.uk
                    • 1237
                    Re: Drive shafts
                    Hi Geoff There is a kit you can buy with split gaiters and an( epoxy type glue ) to solvent weld that are pretty good if you do not wish to strip the shafts.
                    • geoff b
                      • May 2017
                      • 18
                      Re: Drive shafts
                      Thanks Danny, but I was thinking of the ones that can be stretched over the CV using a cone.
                      • A_Hogg
                        • 338
                        Re: Drive shafts
                        The 'split' type in my experience do work as long as everything is really clean but not terribly long lasting . OK as a short term fix.
                        Personally I'd rather remove a couple of circlips than try and fit those stretchy over a cone type, seem to be a real pain in the a--.
                        • scott h
                          • Mar 2013
                          • 670
                          Re: Drive shafts
                          You can buy a kit of stretchy boots and a cone which you slide the boot up and over the cv joint. It works well.
                          • meverett
                            • 662
                            Re: Drive shafts
                            I would agree here, if you have taken the time to remove the hub to get to the driveshaft it’s not much more work to remove the cv joint, once you know where the circlips are, also opportunity to clean up the old grease.
                              • 1648
                              Re: Drive shafts
                              The stretchy boots with cone applicator were originally for the Tripode type drive shafts. Dismantling that type required cutting and stripping off the outer tin can type cover plus boot and replacing with a servive kit. I bought one for my Sierra years ago but ended up getting a complete drive shaft from a breakers yard. It’s the stronger Lobro drive shafts with bolt on flanges that have the circlips. Peter.
