Mudguards brackets bolts and rattles
  • stevepritch
    • Sep 2017
    • 290
    Been thinking for a while on what to try. Settled for stainless plate, milled out at the back to take a rubber pad. Bolted on and spreading the load across the area rather than just the two bolts.IMG_20180926_140341.jpgIMG_20180926_140336.jpgIMG_20180926_140349.jpg
    Re: Mudguards brackets bolts and rattles
    Had a similar problem with mine, with cracking around the bolts.
    I opted to try the 7-esque approach & use windscreen sealant to bond the wing directly to the brackets...so far, on the one wing I've repaired it has performed well. Just need to get round to doing the other one.
