Wing piping
  • 928cdu
    • 230
    Wing piping
    Hi,
    Looking to remove wings and fit some wing piping to my roadster... poor thing has never had any ..
    It comes in a range of different sizes (bead size & flange depth) .
    Can anyone recommend a size that fits the bill for the roadster please ? ... not sure if it was part of the original kit ..?
    Re: Wing piping
    probably wasn't supplied with the Mk1 kit.
    Just measured an off cut and its 1/4 inch(app 7mm) hollow bead with a 1 1/4inch(30mm) tail.
    I think you will have fun trying to get the old fixings undone it may pay to get new M6 replacements.
    • 928cdu
      • 230
      Re: Wing piping
      Originally posted by b_caswell View Post
      http://www.dugdalevms.com/www/body%2...g%20Piping.htm
      Thanks Ben !
      Yes I agree ,I have bought all new stainless M6 bolts in preparation ... the originals were zinc flat headed m6 screws, they'll be fun to remove ..!
      BR .. Richard
      • scott h
        • Mar 2013
        • 670
        Re: Wing piping
        When I was stripping down my Berlinetta, some of the bolts were so difficult to remove that I ended up buying a dremmel as the only tool suited to the tight confines. I think I now have shares in a stainless fixing company for the rebuild!
        • stevepritch
          • Sep 2017
          • 290
          Re: Wing piping
          Originally posted by 928cdu View Post
          Thanks Ben !
          BR .. Richard
          Be careful mixing stainless and mild steel galvanic effect is not good when the meet.
          • 928cdu
            • 230
            Re: Wing piping
            Thanks Steve, I've learnt something new... although I'd heard about steel & ali before.
            I'll be using S/S Nyloc nuts, bolts, penny washers all the way. From memory they'll need to pass thru the aluminium side panels & GRP only.
            ATB .. Rich
            • meverett
              • 662
              Re: Wing piping
              Thanks, I was going to ask the same question as I am nearly ready to fit the running boards. Saved that as a bookmark.
                Re: Wing piping
                You may wish to consider using an anti-corrosive jointing compound . This was standard practice during my RAF service and affectionately known by us 'riggers' as 'Parrot Sh--' due to it's colour!
                Product such as Duralac should do the job .
                • meverett
                  • 662
                  Re: Wing piping
                  I was thinking of using a bonding sealant like Sikaflex but that would be a pain in the **rear to get them off if I ever needed to.
                  • velovol
                    • Nov 2012
                    • 143
                    Re: Wing piping
                    Not wishing to pour cold water on the idea of using stainless fastenings through mild steel and aluminium but being in the marine business I would not recommend this as you will be building in ready made corrosion.
                    Stainless is fine through other stainless or fibreglass and wood, perspex etc. Duralac is a good standard jointing compound when using stainless into alloys but is not a guarantee of no corrosion. Apart from being expensive
                    it's also carcinogenic etc so needs gloves and careful handling. A good alternative is to use PTFE tape on threads which acts as a barrier. Overall you are best off with normal zinc plated steel.
                    • scott h
                      • Mar 2013
                      • 670
                      Re: Wing piping
                      My experience when stripping my Berlinetta after 20 years was that the stainless fixings came off easily. On the other hand the zinc plated mild steel fixings mostly had to be cut off, sometimes with slight damage to the part being removed.
                        Re: Wing piping
                        After 29 yrs, I'll second that. Stop worrying about it, they will outlast you and still be OK
                          Re: Wing piping
                          Oops all mine are stainless.
                          Oh well not going back now.
                          • Ye Ol Ripper
                            • May 2016
                            • 298
                            Re: Wing piping
                            Richard, Ben & Adrian
                            I can highly recommend the following company for all of your trimming needs, as they manufacture the items and have been supplying the automotive industry for years.
                            Most items can be bough by the metre, so its not necessary to buy a 50m roll
                            The Wing rubber trim is almost the size Ben has advised on (1/4" is 6.35mm).
                            ie"Plastic Wing Piping
                            Sized: 1/4" diameter x 1.25" flange. Ribbed
                            Coil Length: 50 metres
                            Colour: Black"
                            Maker of Plastic Wing Piping, Fenderwelt, Anti squeak piping to the Automotive trade. Wholesale inquiries welcome.
                            Hope this helps all fellow Marliner's for the difficult to source trimming part.
                            As you will be buying direct from the manufacturer the prices will be hopefully competitive.
                              Re: Wing piping
                              East Kent Trim Supplies
