Hi all Martin Everett sent me email wanted some photos of my car front cycle wing brackets, took some photos, not very good, trying to put photos on,
cycle wing brackets.
Re: cycle wing brackets.
Hi Ray,
Photos are not displayed.
When you reply click the button as highlighted in the picture below the choose file.
Cheers, Martin.
I hope you succeed with the photo down load as I am very interested in options for cycle wing.
Ray, when you post a reply bottom right "Go advanced" Click on that then scroll down to "Manage attachments" Scroll down again to manage attachments and a new window will come up. Top right browse to select your file then click Upload.
Hope this helps, Hugh
IMG_20180926_140310[1].jpgSomething I did to secure the brackets to the mudguards that I think is transferable
Hi all still trying to add photos to this thread, (very trying), when I do get them on I have disc braked upright not sure what it is? the wing stays are welded to the upright 16mm tube flat plate on ends to rubber mount the cycle wings,CIMG0352.JPGCIMG0351.JPG
Ray, success, pictures uploaded.
Yep it’s Morris Marina or Ital.
I understand now I see how the cycle wings are mounted.
The disc protector plates have been removed and a bracket welded on, a bracket also bolted behind the steering tie rod arm thingy and the mounting frame has been fabricated to fit these two brackets.Last edited by meverett; 17-10-18, 04:04 PM.
