Replacement fuel tank sender?
    I have been contacted by a member who needs a replacement sender unit(the resistor windings have broken up) to fit the ford escort tank on a roadster.
    Any ideas of a supplier or an alternative solution welcome.
    • 685
    Re: Replacement fuel tank sender?
    Sender units do come up on eBay but they are not cheap! eg this one
    If you are not in a hurry it is possible to find one at a more sensible price and I picked one up from a German seller for much less. However, supplies will be dwindling and it may be better in the long run to fit a replacement tank such as the Spridget one that I believe a number of Club members have fitted.
    • meverett
      • 662
      Or bidding for this mk2 estate one. May go for starting bid price.
        How about a look at Jez Cox’s article in Pitstop. Here or there
        • keith_h
          • 549
          Hi Ben
          Did your tank sender chappy solve his problem. If not I have one that I modified slightly while experimenting with something to work in a Marlin long range tank. His for the asking - or postage if he can't collect
          Keith
            Hi Keith, Not had any further feed back at the moment I will try and email the guy.
