Safety Alert Ford Sierra Compression strut problems
  • cabrioman
    • 309
    Re: Safety Alert Ford Sierra Compression strut problems
    Originally posted by A_Hogg View Post
    I thought that the intention of any ARB was to impose a motion on the TCA . The 'D' mounts offer fore and aft location but allow the ARB to essentially pivot within them. So as one wheel/suspension arm moves upwards that energy is imparted to the other side thereby stiffening the suspension . A compression strut, as I see it, only offers fore and aft location and nothing else.
    Exactly right Alan, the rally bods use group A anti sway blade kits in conjunction with the compression strut to stiffen up the suspension as removing the ARB and just using struts actually softens the suspension. Sure the caster location is much improved but it introduces more roll without an ARB.
    I wasn’t too concerned about the roll aspect as a few people, Marlin included had sugesseted the car didn’t really need anti roll control and would be fine without an ARB if it wasn’t for the need to lock the fore aft movement of the TCA.
    So if there is a solution to stabalise the mount and continue to use the struts I would be happy with that as the ARB is not really needed from a roll perspective on the Marlin.
    The other option is a custom ARB to go round the engine, there are a couple of firms in sheffield that can custom build sprung ARB’s so I intend to give them a ring to get a price. It could of course be cost prohibitive and digging out the welder might be the best option.
      I thought I ought to point out that this only affects Cabrios. The Sportster suspension is a different design. One day I dream of finishing mine when I stop fixing up Millie.
        Having the front wheels independent of each other does improve the ride. The ARB is intended for a much heavier car with a higher centre of gravity.
        I have to admit without the rubber bushings rolling over cattle grids, cats eyes and the like is harsher. I almost lost three fillings after the fourth cattle grid on Monday’s jaunt.
        • ggrum
          • 782
          Just to try and bring this issue into perspective, only 5 BMW based Cabrios were produced by Marlin, 2 as kits and 3 factory built. Any others were modified and re-engined by the owner. Although it is unclear if any cars with the standard ARB set up are affected it is certainly worthwhile taking the time to check. As already mentioned by milliemarlin the Sportster is not affected by this issue as it has a completely different design of front suspension.
          • dave_clutterbuck
            • Jun 2012
            • 260
            #20
            My ARB mounting had split similar to pictures in the thread and had not been welded previously, on this occasion corrosion was not an issue in this area.
            I am keeping an eye on the offside ARB mounting as this has been welded previously, not to Dave Billings quality though as pointed out when he did the major shock absorber mount fabrication and welding.
            Time flies Danny, it is nearly five years since we A framed it to Dave's workshop.
            • ggrum
              • 782
              #21
              Shortly after this issue came to my attention I brought it to Marlin Sportscars attention. Following that I had a constructive discussion with Terry Matthews of Marlin and she has sent me the following letter to publish here and in the magazine at a later date, bearing in mind that not all club members regularly use the forum.
              "18th January 2019
              Dear MOC, Marlin owners & Marlin Enthusiasts
              It has been brought to our attention that a very small amount of Marlin Cabrio and Hunters built using a BMW engine, have over time, developed stress cracks around the antiroll bar to chassis mounting plates.
              Marlin Sports Cars wish to stress that this fault is confined to the Ford based cars where the central section of the anti-roll bar was removed to accommodate the BMW engine. We have also been told that some owners have exasperated this problem by fitting a solid tie bar with no rubber bushes.
              We currently have a BMW based Marlin Hunter in our workshop and we are working on a solution that we will be more than happy to pass on to any interested owners. In the meantime we would urge anyone who has this design of suspension and has not yet inspected it, to do so.
              We would also like to add that this issue does not affect any Marlin Sportster models regardless of which donor has been used as they have an entirely different front suspension design.
              Yours Sincerely
              Terry Matthews
              Director of Marlin Sports Cars
              • marlin munroe
                • Nov 2019
                • 32
                #22
                The mileage on Simons Gregory's car was indeed low; however the chassis was an early model and had been the subject of two uncompleted earlier attempts to create a Marlin from it, therefore had been lying around in damp garages for decades before Simon acquired it and stripped it back to basics.
                From the pictures, it does look as if the original factory welds have been the subject of some corrosion, and Simon had cleaned up the chassis and coated it with two coats of Isoflex liquid rubber at the time of his construction. The original powder coating was failing badly at that stage so irrespective of how well he was able to prep the chassis , without grinding those welds back to shiny metal and possibly re-welding them, any corrosion within the micro ridges and troughs of the weld was already well established and free to develop
                The photos seem to show that at least 50% of the problem is the failure of the weld through corrosion. ( under heavy duress of though clearly)
                • marlin munroe
                  • Nov 2019
                  • 32
                  #23
                  Quick correction!
                  I have just checked the receipts. The chassis and kit for this Cabrio were purchased in late 1997, new from Marlin
                  So 11 years and two previous owners before the build was completed by Simon in 2008; then approximately 8000 miles and ten more years before the weld failure was detected
                    <snip>
                    I think it unwise to believe that corrosion is a significant factor in this type of failure. The welds are a focus of the stresses involved. The transition from the thick mounting plate to the thinner chassis is bound to focus the stress. Any corrosion seen is most probably due to the exposure of unprotected metal. There was no sign of corrosion on the unstressed side of my mounting plates.
                    My own car had covered more than 10,000 miles with the shock absorbing anti roll bar mountings. With the rigid compression struts signs of failure were apparent after a few thousand miles.
                    I strongly recommend that compression struts are not fitted to these cars and that the mounting plates of all cars are regularly inspected.
                    • ggrum
                      • 782
                      #25
                      I agree with Paul in that the failure is probably caused by stress concentration as a result of the difference in thickness of the mounting plate and chassis. I suspect the thinner chassis section is flexing slightly under load. However, there will often be a higher level of corrosion in the weld area caused by changes to the crystalline structure in the heat affected zone (HAZ). Correct choice of filler, quality of weld and subsequent heat treatment can all affect corrosion in the weld area.
                      Geoff
                      • Patrick
                        • 463
                        #26
                        Outside observer, not seen any of these in person so I may be talking nonsense:
                        Is there a gusset or any triangulation above the part that seems to be floating free air (circled in red) - other than a thin part of the chassis?
                        If there is not then potentially a great deal of stress on the part that is fatiguing and pulling out from the chassis with the red line being the pivot point.
                        http://www.modelog.co.uk/
                        http://www.mustang67.co.uk/
                        • cabrioman
                          • 309
                          #27
                          I think you hit the nail on the head, there is no support structure of any kind behind the inner hole on your picture.
                          I felt when I had my Cabrio the lack of support on the inner mounting was the problem, as it potentially allowed the arb mounting plate under load to rotate along the inner edge of the chassis leg. It certainly wouldn't bend under load as it is far to thick to allow that.
                          I think any fix to a failed mount should include support in that area and ideally have a revised mount that wrapped around the chassis leg to introduce some triangulation.
                          • marlin munroe
                            • Nov 2019
                            • 32
                            #28
                            I agree re. the stress and the moments of force; not only on the overhanging corner but right back to the upright inner surface of the chassis which is further in than the outside edge of the flange; as pointed out in the photos of the second example on the first page of this stream.
                            However just from the photos and the extent of the corrosion on my own Marlin , it would seem that in my case, corrosion was an exacerbating factor that caused premature separation of the weld, rather than a clean stress crack of a good clean weld.
                            So perhaps a block welded on the inner surface of the chassis to the extent of the edge of the flange would prevent that " see-saw" flex around that pivotal point.
                            However even with the flex potential engineered down to the minimum, repetitive impact stress fractures may still eventually cause the weld to fail
                            Line indicates where the inner upright surface of the chassis starts, area below the red line is an overhanging flange. ( picture "borrowed " from first page)
                              I agree that an upright web on the inner surface of the chassis would be a good enhancement. To fix my car I concentrated on thickening up the chassis and spreading the load around the mounting block. But most importantly reinstating the rubber mounting bushes.
                              For a fuller description see:
                                #30
                                As this problem to the best of our knowledge is confined either to those Cabrio's fitted with the BMW engine and consequently a 'chopped' anti roll bar , or those vehicles that have been modified from the original design and have a compression strut set-up, I would suggest that it's more likely a result of entirely different stresses being imposed on that area.
                                There are a number of Cabrio's out there with the standard set up and greater mileages that have not had the problem.
                                Unless you could cut a section from the mounting plate and incorporate the chassis rail and welds, and then put it under the microscope you cannot categorically say that the failure is due to corrosion or whether the corrosion is a result of failure.
                                Marlin got it wrong in respect of chopping the anti roll bar to fit the M20B25 engine and a number of owners by installing what they thought was an improvement .
                                I was one of those members who had the BMW powerplant in my previous Cabrio
