The timing belt on the 2.0 lump was last changed in 2001/2002, It has only ever since done 2k miles and for a lot of that time, it has sat still under cover or in a garage. It won't be on the road till April and I have a little time to do stuff but I think I'll add in a timing belt change, once I can source one. I would like to do the Fuzz Townshend (Car SOS) trick of cutting the original belt lengthwise in situ and removing it then fitting the new one on in its place and then remove the other 'half' of the original one.
So the questions are:
Have any owners of a Fiat TC changed their timing belt with the engine in the car and if so how did you do it?
Where did you source the replacement belt?
Many thanks!
Tony
Many thanks!
Tony
