Greetings from Plymouth
  • keltonturvey
    • Dec 2018
    • 19
    Hello all,
    I'm a new member down in Plymouth, Devon - the home of the Marlin. I've been looking for my first Marlin car for a while now.
    I'm off to view this one tomorrow morning and wondered if it was known to anyone on here?
    It's got an distinctive hole in the front cowl that I've not seen on any other car.
    Any info or advice gratefully received.
    Kelton
  • davidmartin720
    • 188
    Re: Greetings from Plymouth
    My Triumph Herald based Roadster had a "Dummy Radiator Cap" fitted by Derek Giles when he built the car back in 1981. Picture hopefully attached. David.
      • 2794
      Hi Kelton
      The only archive pictures we have are these, no hole in front cowl top(presumably cut to enable a radiator top up) and also no anti roll bar !
      I don't know the date of the (ebay sale) pictures, they're probably a few years old, two appear taken at the same place and the third has the exhaust on the other side ! I believe the car now has a twin carb 2 litre Ford Pinto engine
      The chassis number quoted for the car is obviously a made up VIN number, but if you could try to get the Marlin kit number(see pic for where to look) I can check the archive for you. Good Luck with the viewing, and any current pics would be appreciated for the archive
      Rgds DC
      • keltonturvey
        • Dec 2018
        • 19
        Thanks for the replies. Kit number 2690. Pics to follow.
          Good luck. I love the bonnet top louvres, are they punched in or grafted in ?
          • keltonturvey
            • Dec 2018
            • 19
            Once the mist cleared this morning it was a lovely day to drive down and view the car.
            Here are a few pics.
            Nice looking car.
            Trials rear end.
            No room for a proper air filter without a bonnet cut out.
            K&N Super flow!
            Battery box.
            Pedals.
              Might it have had a recent respray? Run it and enjoy it for the Summer while planning improvements for the winter. Would this be the Roadster in Pitstop?
              • keltonturvey
                • Dec 2018
                • 19
                Yes, this is the Roadster from Pitstop. I can think of a few of winter projects that need doing!
                The lack of MOT and the asking price are currently putting me off. Going to sleep on it...
                  I hadn't noticed the price. A bit on the high side methinks for a pretty trials car. As a matter of interest does it have the van diff? Lots of low down power and not a lot of top speed. An MOT to make sure it is not a pretty money pit. Good luck sleep well!
                    • 2794
                    Thanks Kelton, chassis number noted
                    Should you buy the car I will send you a little detail on the first two owners
                    Rgds DC
                    • bryannewell
                      • 331
                      Looking at the Rack on the back it either was or was being set up as a Trials Car, may want to check the Rear Diff as a lot of Trials cars had the Marina Van Diff fitted which may not be great for touring
                      • keltonturvey
                        • Dec 2018
                        • 19
                        Good point about the diff. I was told the axel is from an MGB?
                        It’s got a type 9 gearbox but without an MOT it wasn’t possible to get up any kind of speed to see how tall/sort the gearing is.
                        • davidmartin720
                          • 188
                          As far as I can remember the front louvres looked as though they had been punched in, but the rear louvres were a plate rivetted in. David.
