Aluminium Suspension Covers
    Hi all
    I have just finished painting the fibreglass bits and have decided to keep all aluminium bits as they are.
    The only issue for me is the fibreglass suspension covers.
    Has anyone ever had them made up in aluminium?
  • keith_h
    • 549
    Re: Aluminium Suspension Covers
    You have probably got it covered but just in case - make sure you cover the aluminium with some sort of clear etched primer and then several coats of a suitable topcoat. If you don't you will very soon end up with an oxidised (powdery) surface. How about some hot-rod flames emanating from he cowl
    All the best
    Keith
    • keith_h
      • 549
      All the best
      Keith
      Thinking outside the box, if you go down to the hardware shop in Cosy Corner (Hazlemere) he carries a huge range of baking tins - you might well find something with a double flange that you could adapt
        Yep, will do
        All the best
        Keith
          Spray them with a matching silver paint.
            That's what I thought but the misses said it will look rubbish.
            • Ye Ol Ripper
              • May 2016
              • 298
              Hi Adrian
              If you want an Aluminium look to the suspension covers, have you considered an Aluminium self adhesive wrap?
              I've just had a quick look and came across :
              Find many great new & used options and get the best deals for Silver Metal Brushed Aluminium Vinyl Vehicle Wrap Adhesive Bubble Free Graphic at the best online prices at eBay UK! Free delivery for many products!
              If this sort of thing is of interest, research your options as this was just a quick search for you.
                Not a bad idea, will give me a cheap way of looking to see if it looks OK.
                Originally posted by Ye Ol Ripper View Post
                Hi Adrian
                  I've got a heat gun 'designed to work with' vinyl wrap you can borrow if you need to. I've also got some left over wrap in dark green if you want a test piece first.
                  Maybe you should pop over one evening with one of the panels, we can see if it works.
                  David.
                    David.
                    Will do. Will give you a bell over the weekend
                      Out Sunday, at Bromyard Speed Festival, got the Alfa entered!
                        OK maybe not this weekend then as I am helping my mate with his MGB Roadster.
                        I'll pick up with you next week.
