LED Rear Lights
  • fouter
    • Dec 2015
    • 37
    LED Rear Lights
    Hi,
    Was wondering if anyone has tried these lights almost the same dimensions as the original units?
    B07NVH1FG9 they are on Amazon for £14 a pair
    Best Regards
    Graham
  • stevepritch
    • Sep 2017
    • 290
    Re: LED Rear Lights
    Graham if there is an indicator I think there has to be a resistor put into the circuit to stop them flashing like a strobe.
    • duncan
      • Apr 2018
      • 137
      Re: LED Rear Lights
      I'm using LED's all round - you need an LED flasher unit to go with them
        Re: LED Rear Lights
        Don’t forget the hazard flasher too.
        • fouter
          • Dec 2015
          • 37
          Re: LED Rear Lights
          Thanks guys
            Re: LED Rear Lights
            I've just brought them. When fitted I'll add some pictures and information.
            • boustrophedon
              • Apr 2019
              • 89
              Re: LED Rear Lights
              When I rewired Wee Beastie I used a three terminal flasher unit. These have a timing chip in them and they flash no matter what. The old two terminal thermo electric units required a load to work but the three terminal electronic ones do not.
