Spiyda Gauge Matcher v4
    • 2445
    Well that's got to be the best 30mins I have spent fitting a device to make my Marina Fuel Gauge work with the escort sender.
    I used it setting up the resistance figures given to me from the Escort Club -
    75 ohms Empty
    50 ohms 1/4 full
    25 ohms 1/2 full
    17 ohms 3/4 full
    10 ohms Full
    Not cheap, £50 but works a treat and it now reads empty, 1/4, 1/2, 3/4 and full correctly.
    I would definately recommend.
    Will work on any gauge and any sender, whatever the make.
    Re: Spiyda Gauge Matcher v4
    That’s a result, how long as that device been hiding on someone’s shelves!
      • 2445
      They appear to sell a lot and this is the upgraded v4.
      All I know it works.
      • Blue Marlin
        • Mar 2015
        • 314
        I've got one fitted to Brum. It is ideal for her as the Alfa fuel gauge fitted works in reverse to the Escort sender, with 0 ohms being empty.
        I drained the tank then refilled a quarter tank at a time taking note of the resistance readings.
        0 - 75 ohms
        1/4 - 45 ohms
        1/2 - 27 ohms
        3/4 - 20 ohms
        4/4 - 10 ohms
        Pretty close to what you were told.
        Stumbling around in the dark
        Marina based SWB roadster
          • 2445
          Knew I was teaching others to suck eggs but sometimes it's the obvious that gets overlooked.
          Glad it does what it says on the box.
          If you do get one watch all the YouTube videos, makes it very easy to install.
          0 - 75 ohms
          1/4 - 45 ohms
          1/2 - 27 ohms
          3/4 - 20 ohms
          4/4 - 10 ohms
            • 2445
            Next on the list is to get the tachometer working again.
            I went accuspark and meant that the RVI stopped working.
            This device, from the same guys, will convert my original dial to RVC.
            I will let you know how I get on.
            Smiths RVI - RVC Tachometer conversion board + calibration cable -566-
            • Gareth
              • 498
              Cheers for that, very interesting. I'll be looking into this very soon! Gareth.
                You need to stop making things work Adrian, makes some of us feel inadequate
                  • 872
                  Just a reminder, I cut out the Ford sender and soldered in a Marina sender. A bit of jiggling to get the float swing right and I now have a full scale fuel gauge.
                    • 2445
                      • 2445
                      Good call.
                      Many ways to skin a cat.
                        • 2445
                        Todays job completed I. e. Fitted the tachometer RVI to RVC converter from Spiyda.
                        Great bit of kit and works spot on.
                        Think I will leave it there for now and just enjoy the car.
                        Would recommend Spiyda products to anyone.
